Help! How to remove Dometic oven
Rohsman
Mobilvetta KYacht 85
I need to remove factory fitted Dometic oven from a 2019 Mobilvetta K Yacht. I have taken screws out of fixing frame and can wiggle it up and down but not pull it out. How will the gas be connected? Is it likely to be a flexible hose or fixed tube? Heaven knows how you would get to it without stripping out fridge freezer below!
Thanks Ian
Have you had a look through the upper fridge vent?
Gas will be a copper pipe, has it got a roof flue that needs removing?
Got grille off. Black PVC covered copper pipe on left + electrics. Instructions not clear about roof vent but there is one on the roof.
Guess need to remove silcone sealed plate and have a look.
Thanks Guys - Connections behind panel
Thanks Ian
Hi there Ian
I have a 2017 Mobilvetta K-Yacht 85, exact same oven and fridge as yours and want to remove my oven to fit a microwave instead. Seems you’ve found a way, I can do with your guidance please, can you help?
