Riverbankannie
The tap is also leaking and we suspect something to do with the fold up arm.
Can anyone help with how to dismantle the tap ?
Does the Rev /blue button pop off ?
i cant remember the exact method to dismantle the tap, but to cure the leak pull the spout out and pack the O ring with silicon grease ideally or if unavailable Vaseline and push back together
If you can't easily sort the leaking T joint you can buy Fernox LS-X leak sealer from Screwfix and they might be open tomorrow, our local branch is open 7 days a week. It can be applied to the outside of joints but needs a few hours to cure although curing is faster if you spray a bit of water at it. Obviously you would need to turn off the water pump to temporarily stop the leak. Fernox isn't cheap but it is very effective.Update.
We have found a nice CL near Harman’s Cross to stay tonight and cancelled Eurotunnel for tonight.
Because I like nice soft lips ......... I was able to donate this as we had no silicone grease. Have pulled off rotating tap arm and cleaned and re-seated the o ring. A quick test with the pump back on and no leaking there anymore !
However the T junction in the hot water pipe plumbing at the rear still has a leak. I will start a separate thread.
Thanks again.
A photograph of the Tee joint will help
