Heiki roof vent
Exmouth, UK
Autotrail Tribute
Since 2015
I have an Auto trail Tribute 669 and when I was travelling to my daughters before Christmas the outer glaze of the roof vent blew off. Can anyone suggest where I can either get a replacement glaze, which I can stick on, or where I can get a new roof vent. I've measured the internal dimensions and they are 620mm by 400mm. I've googled for one but none in that size are coming up
Our small 400 x 400mm did the same, found it cheaper to buy a compleat new unit than order just the cover.
Ebay, 40cm sq. Just take the top of the new one and refit to the existing one by taking the plastic hinge pins out and refitting using your new top.
Something like this,but check yours first.
Mike.
Not sure where you are measuring. The important measure is the size of the hole in the roof.
I’ve measured the inside of the current vent. I’ll have a closer look at it to see if there’s any identifying numbers or manufacturer.
