Heavy Duty Ramps (1 Viewer)
Oct 23, 2017
132
91
Cambridgeshire
Burstner 747 - 2
Has anyone been able to find ramps that are light weight, of a good height at least 8” high. Willing to sacrifice them being heavier to get a strong pair. I’ve been using for the last 15 years a pair that I made out of wood.
What do you use?
Aug 18, 2014
24,098
137,662
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
What do you use?
I used to use a pair of actual metal ramps made from angle iron. Didn't weigh much at all.
8,973
47,265
Worcestershire
Bailey Adamo 75-4t
March 2018
To me they don’t look big enough, and resting your tyres on them while parked up can’t be good for the tyres.
Worked aok with our motorhomes. Have used them for years. No issues with tyres.
1,078
1,044
Cumbria
Pilote P740FC
We have those, and do find the tyre radius is too big for the recess - but they do a variant with 3 recesses, which I wish we'd got instead. But they are very heavy, so we are currently back using an old pair of Fiamma Level Up ramps to save weight.
3,199
100,729
Shropshire
Carthago chic e-line
Since 2013
I took a good sharp saw and took the peaks off,been using them on our 5.3 tonne with 225/75/r16 tyres on and had no problems.
5,512
22,476
Cumbria
since 2011
I have the Milenco Quattros and have found them to be no problem. I've even used them for maintenance jobs too. I don't know what you consider to be "heavy" these aren't "light" but they fit into their own carry bag and tuck away nicely in our garage ?
As for them damaging your tyres, I'm not so sure, they're made from injection moulded plastic that has got to be a magnitude softer than the tarmac that your van tyres run on every day ?
TerryL
6,264
8,330
North East
Low Profile
Have used Milenco Quatros for as long as we've had our van. Never had any problem but of course I make sure the wheels are properly seated in the depressions and not on the edges. Yes they are quite heavy but so is the truck! Never found anywhere I wanted to stay without being able to level us up with these.
5,051
17,744
Todmorden
Van conversion
FUNSTER in a PVC
I have used Milenco Quattro 3s for 2 years now and they not caused any damage to the tyres ( road surfaces are rougher ) and they are great if you need to observe anything under the van.
3,861
10,866
PVC
1995-2004 & 2017》
This point has been mentioned in the past... However I cannot see the differance between parking on these ramps and on a rough gravel hardstanding.
I use these ramps and have so for many years and never found they damaged tyres in any way..
245
731
Bradford
Sunlight T68 XV.
Newbie
I now also use my Quattros when doing some simple jobs under the Healey, rather than the heavier metal ones, or the four sill stands.
