Heating and hot water
clifflea
NN84GF
Bailey autograph 75/
Hi, how do you get hot water in a Bailey autograph 75/2 when off grid and no hook u. Cheers
Cheers Phil. I have pressed the gas button but nothing seems to happen
Is the gas tap on the manifold that isolates various lines turned on?
And I assume that other appliances are working on gas correctly
Once selected , find the exterior flue for your unit.
Put your ear by it , you should hear fans running and you can feel warm gases being exhausted , if it's working.
If it is hot water will take about 15 or 20 mins to heat up.
Depending on the unit you should see an amber lamp when working , maybe a red lamp if there is an error etc.
Hi, all sorted had the wrong colours for the gas being on. I’ve only had the van for a couple of month. Cheers all
