Whale.What heater we talking about? So many out there.
It would be a 500 mile trip to go back to dealer. It is under warranty and Whale have supplied a new one. It also won’t work!! Asking if it could be anything ie electrical.Take it back to whoever installed it
Have a word with the dealer. They may be happy that you use someone local and bill it.It would be a 500 mile trip to go back to dealer. It is under warranty and Whale have supplied a new one. It also won’t work!! Asking if it could be anything ie electrical.
It worked on gas but not 240v then lock on came on againLet's hope that they tested it after fitting, never assume anything, so it could be something simple - running on gas? running on 240v? both or either turned on? 12v turned as the heater will need that to function.
Yes all checked . Reset does not work either.Have you checked the 12v power supply fuses on the Sargent PSU also the fuses on the EM50 or EM40 module that is behind the drivers seat ? (If an Autotrail Motorhome)
I would have expected the dealer to check for an electrical problem before they fitted a new heater, if not I'd not be confident getting them to due any other work.It would be a 500 mile trip to go back to dealer. It is under warranty and Whale have supplied a new one. It also won’t work!! Asking if it could be anything ie electrical.
