Heater only blowing cold air NOW. Help
Midlands
IH 630 FL
Hi, my burstner fan seems to be stuck on cold air only , fan seems to be stuck on and won’t switch off, only just had van (18 moths old) so not sure where all fuses are, have tried some but fan still in, help were freezing
Have you turned the heating off as it sounds like you don't have elec/gas heat to blow around but the fan is still trying to find some.
Martin
IF the gas supply has gone, OR have you got one of the "Safety" "Snap" valves at the Tank. When that trips all the gas is cut off they are suposed to act in event of an accident.
If that is the case all you do is press the reset button on the valve to restore supply.
P.S. I got caught with this after changing a gas bottle the first time after purchase as I did not know of it`s existence.
Will not turn off
Have just had gaslow fitted. Tanks full.
All tested okay.
Not sure where a rest valve would be
Gas to hob works and fridge.
Might be worth posting what controls and system you have but I don't know it well enough anyway so I'm out, best of luck.
Martin
Hubby driving at moment and I can’t reach book about, will get back soon. We are in a burstner viseo 680g if this helps, 18 months old
Tell us what heater and control panel you have, without that info we can just guess.
Depending on what system you have, they may be a reset setting for your heater that could get it working again,
Hi all
Seems we had not shut it off properly from last night, has to be shut down in correct sequence.
Now we have found a light bulb gone in smal lights around van, need to find right fuse. So much for our holiday.
Hi all
Do you mean one has failed or are none working. Are they orange marker lights?
Yes, the marker lights have gone, one is black, so bulb gone and blown fuse somewhere
The fuse for that will be in the base vehicle fuse box and hopefully your manual tells you where this is which fuse.
Martin
Hi all
Ah it's things like this that make a holiday memorable (y)
Finally got to Coniston lake, dog walked, dinner and wine
Yes but we really only came up north to have ‘new’ satellite repaired. That’s done. Will try Lake District now, fuses later.... was our 51st wedding anniversary Sunday too.
Congratulations - Happy wedding anniversary - one day late but it's the thought that counts. :clap2:
Happy Anniversary!!!
