Ignore last post. Just been to take a photo and I could see the tree through the reflective foil. I could do with cutting the non slip stuff back, but it doesn’t cause a problem.
Did the foil come with the unit?Ignore last post. Just been to take a photo and I could see the tree through the reflective foil. I could do with cutting the non slip stuff back, but it doesn’t cause a problem.
I can in MPH, it’s Kilometres that throw me. Yes the foil came with the kit. I bought it from Halfords. I sat in the drivers seat once the unit was working, someone moved the foil about until I could see it clearly, then it was stuck on the inside of the screenI've no need for this. I can always guess my speed within 3mph. Maybe it's a superpower
That is what I told the magistrate ................................. didn't work thoughI've no need for this. I can always guess my speed within 3mph. Maybe it's a superpower
and more accurate than the Fiat speedo providing your at a steady speed.My Garmin satnav shows the speed. No problems and very safe.
colyboy
And not driving through a long tunnel or similarand more accurate than the Fiat speedo providing your at a steady speed.
At a true 65mph on the sat nav it shows as 70mph on the speedo (Ducato x250) and also on the hud. I haven't noticed any pronounced lag on the sat nav.and more accurate than the Fiat speedo providing your at a steady speed.
You can also get an app for any smart phone too. Not sure about HUD though?.
Example on Amazon, they seem to be all about this cost?. Amazon product ASIN B01LJCA1B0
One Benefit, is that the GPS signal will likely be more accurate than the Vehicle readout.
Yep been using one for the last 6 months. Just returned from a 5k trip around Europe and it was perfect for speedo, engine temp and battery voltage (could choose other displays though). Changes from klm's to mph easily. Bought from Amazon for £13 If I recall correctly!Anybody using a heads up display to overcome not being able to read the speedo in the gloomy recess of the Ducato X290 dash? I was looking at the Scosche HUD2 which uses the OBDII port. Not expensive, but is it any good?
I don’t mean to be rude.....but.......the Specsavers ad comes to mind!
Is the speedo really that bad? If so,how the hell did it get past all the R and R? Bizarre!
That's true, but the Ma Way I mentioned above (#35) can be adjusted for this, so it reads true.a feed off the OBD port which presumably shows same speed as original speedo, ie. over-reads
