Headlamp levelling device (driver control) does not need to work on motorcaravans!
Fareham, Hampshire
Since 1998
Headlamp adjusters DO NOT have to work on motorcaravans! See last line below (copied from the link below)
MOT inspection manual: cars and passenger vehicles - 4. Lamps, reflectors and electrical equipment - Guidance - GOV.UK
Headlamp, position lamps, daytime running lamps, stop lamps, indicators, hazard warning lamps, fog lamps, reversing lamps, lighting ‘tell-tales’, trailer electrical socket, electrical wiring and battery rules and inspection for car and passenger vehicle MOT tests.
4.1.5. Levelling devices
Make sure any manual headlamp levelling devices (driver controls) work by:
  • switching on the dipped beam headlamps
  • operating the manual levelling device
  • checking that the headlamp beams move up and down
  • returning the levelling device control to its original position
Vehicles with high intensity discharge (HID) or LED dipped beam headlamps may be fitted with a suspension or headlamp self-levelling system. If these systems have been fitted, they must work.
Sometimes it is not easy to determine if the self-levelling systems work. In such cases you should give the benefit of the doubt.
You can identify HID headlamps from:
  • ‘DCR’ mark on the headlamp lens or body
  • an igniter module or inverter behind the headlamp
  • taking a few seconds to reach full intensity
  • a bluish tinge to the light
HID headlamps use high voltage. You should take care when inspecting these headlamps.
The check of headlamp levelling devices does not apply to motor caravans.
