Half way house solution to eBike charging... (2 Viewers)
Jun 28, 2021
32
14
Hymer Exisis
Having been away for a couple of weeks we came up with the age old problem of charging our eBikes when not in EHU
With some research I see many convert to Lithium at vast expense, so I started thinking
Has anyone connected a good quality inverter (pure sine 1200W) to the vehicle battery and charged the eBike battery only when driving?
Seems a cheaper solution although I am concerned about the load on the vehicle alternator being too much
Comments please...
Nov 4, 2011
6,338
43,649
Uk
wouldn’t an inverter wired to leisure battery still be charging whilst driving
Kannon Fodda
2,865
8,745
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
What size ebike battery? 1200W is big. 300W inverter more than sufficient to do my Bosch battery. Make sure it is pure sine wave.
Connected to the vehicle battery will work but ensure it's fused and you have switch to disconnect moment you stop engine or you'll have a flat starter battery in no time.
N
Jun 28, 2021
32
14
Hymer Exisis
I'm not really sure how it works. I think the leisure battery only charges IF the vehicle battery is full charged.
I intend to add a switch to isolate the inverter when the motor is not running
N
Jun 28, 2021
32
14
Hymer Exisis
The eBike batter is 720W (yes a large one) The charger draws 172W (240V and 1.5 amps) so a 300 would be fine
Kannon Fodda
2,865
8,745
May not be a good idea. Wires between starter and leisure batteries via the relay/charger may be small. And the relay/charger limited in size. May not be able to charge the leisure and also the inverter at same time.
Halway house of inverter from direct connection to starter batt will be better providing inverter is switched off moment engine not running. Ideal is to upgrade wiring with b2b charger from starter to leisure with inverter off leisure.
Nov 13, 2011
1,557
5,492
Lincolnshire
PVC
30 years
Where are you thinking of siting the inverter? You need to keep the 12v leads to the inverter as short as possible.
Geoff
Jan 10, 2015
275
530
East sussex
2002 Eura mobile
Since 2014
Geoff
I have a giant 36v e-bike which I recharge while on the move with a 12 to 36 volt charger running from a direct fused connection from the leisure battery. I try not to let the bike battery discharge below half so I’m really just topping up. Still takes a few hours though.
Got the charger from eBay & with a specific connection for my bike.
Oct 12, 2009
11,490
25,433
A Class N+B Arto 69GL
Since 2009
The leisure battery will be charged with the engine running but, when controlled by a normal automotive regulator, then after the engine battery reaches full charge, the regulator drops the alternator back to a low charge, so the leisure battery does not receive much charge.
The solution to the low charge from the alternator to the leisure battery is provided by @Kannon Fodda - to fit a B2B, also known as a DC-DC. Both of these ensure the alternator is giving a high charge to the leisure battery. You must also ensure the wiring is of sufficient size to take the loads you need - calculations required.
jumar
4,112
13,269
Spain
Hymer Tramp
Since 1994
My inverter is connected to my leisure battery, both my Engine Battery and Leisure battery change from the vehicle Alternator....I charged two eBike on the road...
However....I've since gone Lithium and support this with more solar and a DC2DC...
We remained stationary in a shady location last week...charged bikes after each day in the final day my leisure battery was 27%. Time to drive to recharge it....brought it up to 70% and finished it off with solar...
Feb 19, 2018
5,636
90,868
EAST ANGLIA
Murvi Morello
Since 1975
I have a 1500X VTOMAN Powerpack with a 230/50Hz pure sine wave inverter fitted and can be charged by Solar, mains or vehicle cigarette lighter plug while travelling.
I have not tried it yet but I presumed that I could just plug my bike battery into one of the 3 230v outlets when power pack is fully charged.
Is this not possible? 🤔
N
Jun 28, 2021
32
14
Hymer Exisis
That is indeed a solution, except I want to avoid the weight of the 1500X.
May 15, 2020
126
282
York
Laika Ecovip 709
Learning
We had the same problem 2 x 625 watt batteries tried a combination of charging sites EHU, taking a charger out and charging at a pub, cafe..,
Then decided that Lithium batteries was the only really workable option.
N
