Habitation door not locking from key fob ?
Midlothian
Elddis encore 250
6 years Motorhome 15 years caravaning
We are in elddis encore250 in the last few days the habitation door does not lock via the key fob or the locking button on the dashboard ? It looks ok with the key but would be better if we could get to the bottom of problem ?
TIA some photos of fob
If you Are you anywhere in hot weather, try pushing door in slightly near handle and at same time press remote to try and lock it .
It just might be heat related?
Worth a try 👍
If it doesn't lock with the button (which is electrical not infra red) i would suggest looking at the lock or wiring to the lock.
usually a case of the wiring between door and frame. Some vans have small brass sprung contacts rather than wires. A bit of dirt or corrosion will stop it, as will the door being out of adjustment
Does the ket fob also arm an alarm?
If it does are all the trigger switches in the closed position.
No hatches slightly out of alignment with the switch or the magnetic switch.
Key fob alarms front doors ok just hab door not locking I can’t see any contacts on door or frame I thought it was total wireless might be wrong though
Contacts are low down on the sliding door at the far side away from the opening. I'm taking it yours is a pvc? Do the back doors lock when you operate the remote
It's a coachbuilt . I'd imagine if a pvc he would have said sliding door rather than habitation door.
Ours is a encore 250 7.4 m long
Have you left the cab door open. Ours won't lock if the cab door isn't shut properly
