Habitation Door Adjustment (1 Viewer)
Jun 6, 2020
332
243
Apache Hi Line 634
All,
Need some help,
The habitation is not aligned (Auto-Trail, Apache).
The top of the door sticks out a bit at the top and I understand that I can move the strike plate in order to address. However the over all alignment seems to be out, there is a larger gap on the left hand side, than the right which is tight to the door frame.
Anyone know how to align the door so it is more square within the frame (as opposed being offset to the right as you view)
Regards
M
Jun 6, 2020
332
243
Apache Hi Line 634
A towel and a piece of 2x1 wood which I wedge in the door and gently rocked forward and backwards with the door nearly closed and managed to get a few mm movement from the door edge. Not rocket science but did the job …..
