- Oct 24, 2023
- 10
- 12
- Carado i338
- Caravan since 2014, Motorhome 2025
today I've been installing these wireless cameras from aliexpress which I am very pleased with . I discovered an interesting fact when I did a negative disconnect on the temporary wiring that I'd done to test them, and found they carried on working!
I believe the casing on them has continuity to the -ve side supply cable, and as I have a couple of metal screws from the casing into a metal part of the vehicle skin, there is a path to vehicle ground via the camera's supply cable.
anyway this doesn't seem like a good idea...as the cameras would form a viable alternative path to ground if I did a negative disconnect at the battery .. and of course they are only thin supply cable ...so would not be a good plan for them to accidentally carry to ground for anything significant.
I'm pondering whether 2x small (1 amp or so) fuses on each of the -ve and +ve lines to each camera would suffice to protect things, or do I need to go find a fully (12v and gnd) isolated small 12v to 12v supply for them?
