Grey Water Tank - Connector and Pipe Required - Classic Hymer B544
jo10000_6
South Yorkshire
Hymer B544 Classic
Jan 2018
I've been cleaning the water tank - Puriclean - which has meant a few fills and empties and whilst I don't mind the two bucket under the motorhome I wondered if anyone knew which connector went on the pipe so that I might consider going over the grate which I cant perfectly get on hence the pipe fitting request.
Its a 1993 Hymer - B544.
Jo
Wonder how original it all is or has someone been there before and made a few changes. We have an extension pipe for the Laika. 50mm pushes on over the outlet. Made a 50mm to 25mm adaptor for the other end so I can connect a longer pipe and plumb ourselves in if we are staying for some time.
Hi All
Firstly thank you for all your replies.
Just so you know whenever I post I try to do a bit of research on my query to see if I can self sort or have to ask you guys.
Couplings however not really my thing and when I look at the above there are so many different ones and places you can get from agricultural to hose people etc.
So on Wednesday I was doing just that on something totally unrelated. Happened to be watching a YouTube video of a Hymer like mine but a Mercedes one and this guy is going through the features as they rent them. Low and behold he opened the rear bumper end and pulled out a long pipe for disposing of water if you cant get to grate. Now this Mercedes was exactly mine even down to the K plate. Wanted to look asap but its been raining quite a bit but I've just gone out and I have the same long pipe and connecting coupling (width of the bumper).
I'm sorry to have put you to the trouble but as always I'm grateful for the replies. I have to say its not the first time I've found something new about my oldie but goodie motorhome by watching a video. Learning all the time...…(y) …….loads more to learn (y):eek:
Jo
This may fit...............
https://www.johnscross.co.uk/products/auto-trail-waste-outlet-extension-hose-2m.html
Extension hose that pushes into the waste tank outlet of your vehicle to enable your grey water to be discharged over a suitable drainage point.
  • 2 metres in length
  • Complete with 40mm rigid pipe to push ditectly into waste tank outlet
  • Will fit all Auto-Trail vehicles from 2002 model year onwards
  • Colour of pipe may differ from picture
That looks like a coupling used on compressors. Never seen one on a MoHo.
Craig
RMBs have them, its a standard twist lock connector widely used in industry for air and water hose couplings.
