Grey waste sensor (1 Viewer)
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
We have a Knaus 700 TI (2013). On the last trip, the grey waste sensor decided to play silly games. In the space of 24 hours, when we had just emptied it, it showed 100%, 80%, 40% etc., etc! Now I could just ignore it, but if Ive got it, I want it to work properly. Unlike the fresh water tank, I can see no way of accessing inside the tank to check for gunge build up. Anyone had experience of this, especially on a Knaus?
Keith
Nov 6, 2012
196
279
Guildford
3litre Bessacarr 765
Restarted 2012
I have the same problem. I assumed the sensor contacts were contaminated as the M/h is 9 years old. There is a large cap on the base of the grey tank which I unscrewed easily. The small amount of residue waste was surprisingly cleanish and even feeling around inside the base of the tank was clean. The downside was after all my effort I couldn’t locate the sensor so back to guessing!!! The joys of motorhoming.
Jan 22, 2012
1,499
2,321
Wigan
Knaus Sun TI 2012
We also have a Knaus Sun TI 700LX the sensor on the waste has always been totally inaccurate. We have ignored it for last 5years , Its not an issue for us as we tend to keep a large bucket outside with the waste continually draining into it, that way we avoid the smells of long standing waste water.
grasscutter
2,575
10,014
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
The sensor on our Hobby has developed a mind of its own on this trip.
We get a red flashing full waste light. No rhyme or reason to when it starts or goes off.
Will get under van on our return and disconnect it.
Nov 4, 2011
6,338
43,650
Uk
My sensor plays up occasionally, remove it and find the prongs covered in muck.
May 24, 2014
654
2,564
North Devon
Autosleeper Kingham
Since 2013
You'll find many threads on here over the years on any number of makes of Motorhomes as well as some solutions albeit short term ie swill the tank with lots of coke cola!
I have disconnected the warning buzzer and just empty the tank as regularly as possible (in proper sites l may add).
Apr 19, 2018
58
153
Hello Pikeman, I've also got a Knaus and, not only does it give wrong readings, it also beeps every 15 seconds because it thinks it's full.
Did you ever find out how to get to the probe/sensor?
Pikeman
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Hi Ken,
No, I still haven't found out how to access the probe. I tried back flushing the tank, whilst it had 6 litres of coke in it, it went from 90% to 80% when empty, so basically no joy. I even joined the Knaus owners club, only to find that they don't have a forum where you can ask other owners - bloody useless!!
Apr 19, 2018
58
153
Thanks for the reply.
On the plus side, at least you haven't got the beeping every 15 seconds.
I'll do my best to find the probe and if I manage it will get back to you.
138go
3,276
14,616
Carthago 138
Since 2001
If it has a CBE Control Panel you can turn the bleep off. Our Control Panel bleeps when the water is getting near empty so I switch it off if we are on the way home. Otherwise I panic and try and find a tap (y);)
Apr 19, 2018
58
153
If I could turn off the alarm it would solve all my problems - I don't think it's a CBE panel, though.
319148
Sep 11, 2022
Knaus
we have this panel in our Sky TI 650 and it has for a while not switched the pump once we have arrived on site and it takes a lot of pressing on the water symbol before it comes on which we need to sort but last weekend the alarm (silenced alarm) showed red flashing and the tank was flashing, hardly any water is waste tank and still is was flashing red? unsure of how to rectify this, also the waste tank when emptied stinks fouls , bad eggs etc horrid, how do we rectify this, maybe buy a new control panel?
Mar 12, 2021
468
657
Renfrew Scotland
kontiki sport
20 years tugging .5 years MOH.
Got the same problem 2 years old swift kontiki, I very seldom check levels anymore just go with instinct you tend to get a feel for it.
Or you could fit Mopeka Bluetooth sensors I’ve got them on gas bottles so accurate.
Jul 31, 2014
1,962
3,292
West Yorkshire
EuraMobil Activa 820HS
Do you have an access cap/opening to your waste tank?
Ours is located beneath the floor with a trap door above. There’s a giant cap that can be unscrewed for you to see into the tank.
I occasionally squirt the hose into her and around the inside of the tank to clean off any residue build up.
I’ve found that this also cleans the sensor which helps give a better contents reading/more accurate
Apr 27, 2008
11,980
14,396
Eastbourne East Sussex
Hymer low profile
Since 1972
My current motorhome waste tank reads empty when it's empty and 25% when it isn't. At least there's no bleeps or buzzes.
As before I just assume if the fresh needs filling the waste probably needs emptying. Of course the fresh water gauge isn't particularly accurate either but at least full and empty are correct.
