- Jun 12, 2018
- 139
- 269
I have noticed that the protective material on my drivers side step is lifting in a few areas. Is there a way to stick it back down with a glue ( not superglue) or should I just trim the raised pieces?
That sounds a goer. Have some in the garage so will have a go with that!carpet spray adhesive..
basically a contact adhesive in aerosol form.. I've used it to reline my van with carpet
You would have to spray it into or onto something and then use it as a contact adhesive as in my experience it goes everywhere straight from the can and I certainly wouldn't be spraying it near my van.That sounds a goer. Have some in the garage so will have a go with that!
Maybe onto a little artists brush.You would have to spray it into or onto something and then use it as a contact adhesive as in my experience it goes everywhere straight from the can and I certainly wouldn't be spraying it near my van.
sprayed onto small brush, applied and held down. Appears to have worked!You would have to spray it into or onto something and then use it as a contact adhesive as in my experience it goes everywhere straight from the can and I certainly wouldn't be spraying it near my van.
.. the spay cans I use have a narrow spray beam.. width controlled by how hard you press the spray button..You would have to spray it into or onto something and then use it as a contact adhesive as in my experience it goes everywhere straight from the can and I certainly wouldn't be spraying it near my van.
