- Sep 29, 2019
- 3,386
- 7,826
- Hymer Exsis
- 20 years
Dodged a bullet here I hope!
Glow plug warning came on the weekend, Fiat Ducato 2.3, 2013.
Did some testing after finding the glow plug relay (right hand side as you look at engine behind headlight).
Power supply and relay all good, glow plug resistance however had three of them at 1 ohm and one at 0.6 ohms. Tested again when cold and all within normal range and warning disappeared. As soon as engine warm, fault comes back. Disconnected the wiring and infinite resistance so wiring good.
Identified the glow plug 1, which is on the left looking in, and as luck would have it, could just about get to it with just moving the intercooler pipe out the way, all the others were an EGR and throttle body out job. Did lots of reading about how easy they are to snap off and crapped myself. Mechanic at work advised if it doesn’t move then don’t touch and send to specialist immediately.
So, got my 8mm deep socket and used a torque wrench with lots of release stuff soaked in after getting the engine warm. I barely put any pressure on and it just unscrewed by hand after the initial turn.
Replaced with new one and all sensors now reading the same resistance and warning gone. I did ask the mechanic about replacing them all, his view was just do the one as the risk of snapping them off is so high.
In short, cost me £11.50 and I am very relieved I haven’t got to remove the cylinder head.
Hope it helps others.
