Genius idea for maxing out on solar
Surrey
Rapido 854f
Since 2012
Unashamedly lifted from another forum but too good not
to share.Great for adding capacity when you need it most
If it's closed, I wonder if the output is half, or almost zero. It depends on how it's wired.
Also, any shadow cast by the runners will kill the output, even if it's only on the edge.
Unashamedly lifted from another forum but too good notView attachment 688418 to share.Great for adding capacity when you need it most
There are a few along the same lines on YouTube, but this guy's setup I saw a while back is pretty neat.
Not necessarily as it'll depend what type of panels they are, some are able to still produce a good amount with some shading.
It's clever but I wonder how rustproof it is? They look like the things you support cupboard drawers on.
My 185w panel is recent and nothing special. If I cover half of one if the 27 square cells, output drops by about three quarters.
Just to add, if I was going to do the slide out version I'd have it so that the bottom panel pulled out that way the top panel wouldn't have any shading and the lower would wouldn't either if it was pulled out far enough.
They look a bit bigger than ones used for drawers, you can get aluminium ones.
Sensible thing to do would be to switch them so only the top ones are connected when slid in. Won't last long with kitchen draw runners.
He fitted them 4 years ago and they are still going working fine as per his last video a month ago. (y)
He is American if in California or somewhere with a similar climate probably OK, can see the runners lasting in the UK.
I find that if I give my panel a wipe down with a damp cloth to clean off the dust I can double the output.
I now have a truck windscreen squeegee on a short pole so that I can poke my head out of the hatch and wipe it down every couple of days.
They have had the full gambit of weather having travelled down through Central America and are now in South America, why so dismissive?
Not dismissive I just wouldn't expect standard draw runners to last outside.
Logically I would not expect the panels to be extended and retracted much more than a handful of times in a week and even less if your parked up for a few days at a time.
I would have thought that grit and road detritus getting in the runners will be a bigger problem than rain and dampness
The top panel looks like it may tilt when extended giving even better output
Dennis
You could ditch your awning and use the panels instead, so an initial weight reduction.
