Hi, I'm installing a multiplus II, 12v, 3000, 120. Some times I will be using a Champion 2200 duel fuel, to charge the 3 × 200Ah Lifepo4 batteries (in parallel).
The generator shows:
Starting Watts: 2500/2500 Propane.
Max Watts: 2200/2200 Propane.
Rated Watts: 1900/1710 Propane.
AC Load: 1 x 240v 13 Amp.
Frequency: 50Hz.
I have a Digital Multi Control, to select maximum load from AC. If I set that to 10A or 11A, what would the charge rate be, from the Multiplus?
Frequency: 50Hz.
