Generator- Excuse the Newbie Question!
Bridgend, South Wales
Lunar Roadstar 720
On & off 5 years.
We have a small generator, an IMPAX Inverter 8001 Generator that has outputs for 12v & 230v.
Never needed to use it before as the sun always shines on Motorhomefun members :) and I don't like to use a generator because of the noise factor! The generator has both standard 230v output socket and a 12v output - I'm guessing I should use the 'mains 230v' output to recharge the van as I would if on a site with power?
Is there any merit in using the 12v output to charge batteries?
You've got it right.
I have a 12v and 240v outputs on my little Honda genny.
I use the 12v to charge a battery directly.
The 240v plugs into the van like an EHU.
The quickest way to put power into a battery is via the 12v.
Very rarely use either these days with my solar stuff on the roof.
JJ :cool:
JJ :cool:
Do you connect the 12v output to the battery and the 230v to the van at the same time?
You risk overcharging the batteries if you connect them directly to the 12v output of the generator. You can certainly charge the batteries with a genny but to be safe you would need to monitor the charging voltage and current.
If you use the charger built into the MH by using 230v into the EHU then it will be much safer and better for the batteries as the charger, if it's a good one, will follow a correct charging profile, dropping the voltage as the batteries charge.
JJ :cool:
I think it depends on the output of the generator. I would suggest in most cases the most efficient way would be to allow the charger to do its work. You would of course need to ensure the charger does not pull more power than the generator can supply.
You might well be right... but in my case (Honda1kw) I can assure folk that it is quicker to charge the cab battery direct from the 12v output rather than go via the van's system... I know this because I have needed to do so in the middle of nowhere!
JJ :cool:
I must have got lucky over all these years I have charged batteries from my Honda 12volt output...
This is something I have actually done over and over again in real life...
JJ :cool:
It probably has a constant 12v voltage output which isnt good enough for batteries.
They need 14.4v to begin charge then drop eventually to 13.6v when charged
Well, I'm confused...
My Honda genny charges a flat battery perfectly well allowing engines to start!
I'm not interested in how many volts or amps or watts are optimal for charging stuff... what I am interested in being able to get vehicle(s) with flat batteries going by charging them with my genny via the 12v output socket.
This isn't based on reading stuff on the Internet... this is based on what I have ACTUALLY DONE in the real world many, many times.
JJ :cool:
JJ :cool:
I can only assume that your inbuilt van charger has a very low charge rate to the engine battery.
My Honda EU20 will only supply 8amps at 12v but the onboard charger can do up to 25amps on mains power to either the habitation or vehicle batteries so would be over 3 times quicker on mains feeding the onboard charger.
It completely depends on the power of the charger in your van.
According to this site The 2KW honda generator outputs 12v at 12A.
If you have a 10Amp 240V charger in your van then the 12v output on the generator will be quicker.
However, if you have 15A 240V charger in your van then the 240v output on the generator will be quicker.
It is all down to how many amps you can get into the battery. There is no single right answer as it depends on the equipment you have on board.
Generators should always be run at the same time as roof top aircon. Cools the van, charges the batteries and pays back neighbours with who play loud " music" or worse have door slamming competitions in the middle of the night.
I don't know or care what amps my van charger puts out...
The one time I needed to charge a flat battery on my new (to me) motorhome (alternator belt broke) the van charger via EHU from the genny was too slow...
I used the 12volt output... no problem.
But PLEASE everybody... DON'T do what I do...
...do what all the experts with their knowledge of amps/volts/watts and B2B and Lithium batteries with BM setups do...
They are the ones who know the real stuff...
I just do things the way that work for me!
JJ :cool:
JJ :cool:
Thanks for the effort
  • Funny
Reactions: JJ
JJ :cool:
Not lucky at all, as I said you can certainly charge a battery from a generator, of course you can and it's probably no different to using a cheap mains charger which just chucks out a constant voltage. But modern chargers are a bit more clever though.
