Hi we have a Adria Motorhome with a 11 kg and 6kg Calor bottles the moment we are planning a trip to Dubrovnik and were considering fitting a gas slow bottle is it possible to use Calor and gas slow any help would be appreciated thanks
They can be separate but can't be used together. Obviously if that's your set up then use the Gaslow and keep the Calor in case of emergency. You can top up the Gaslow cylinder at your convenience and only use the Calor if your Gaslow runs out because you cannot replace or refill (exchange) the Calor until you return to the UK. Make sure you've the correct or all adaptors for the Gaslow for the countries you are visiting.Hi we have a Adria Motorhome with a 11 kg and 6kg Calor bottles the moment we are planning a trip to Dubrovnik and were considering fitting a gas slow bottle is it possible to use Calor and gas slow any help would be appreciated thanks
i would just get two gaslow or gas-it you can fit your shelf if you can use a spanner and a screw driver and drill take you a max of two hrsThanks for your help i have a 11kg and i think a 6kg Calor light I was thinking of fitting a 11kg Gasslow and keeping the 6kg calor would I have to get a dealer to fit the set up and would it be a problem going through the tunnel thanks again for your help.
