Gaslow views
Thanks for reply, how much do they cost? How many will I need ? Thanks in advance for any help with these questions
£26, i know these are Gasit but would likely be similar price.
<Broken link removed>
You can also get a gaslow/gasit lead to screw into the filler point so you can connect a European gas bottle, you need what's called a jumbo adapter for the bottle too.
Handy if you don't want to move the van when on a site long term. Our 2 x 6kg bottles only last 4 weeks when powering the fridge 👍
I can get links if anyone interested.
No LPG in the northern climes as it freezes in winter ( really really cold not oh where's me brass monkey! ) When you buy a gaslow system you should get the full European refill adapters with it, Spain , France, Germany, Belgium ,Holland etc no problemo If you over winter in warmer climes either take the van or the gas bottle to the refill (petrol) station and no problems after 5 full refills you are quids in!
Propane works well enough down to -30C, with a boiling point of -40C. Southern european Autogas tends to have butane mixed in, but British and other northern countries use pretty much pure propane. If it is much below -30C gas boiling points will be the least of your worries.
You can not fill lpg at the pump ,you
Still no good if you've gaslow or has it !
Absolutely I was just sharing what the Finish do CNG or LNG if you click on the link you will see the fins also use LPG Bottles which could be used in a MoHo and of course as LPG is a what is used in the GasLow clearly LNG and CNG would not be suitable
About all you could do is get a transfer hose and hold the donor bottle upside down above it and hope gravity works (not had much success with this method before).
We have had refillables ( AluGas ) almost since we started.. Must have saved us thousands over the years
I fitted Gaslow and currently on country no 30 .only issues filling was Italy where its illegal to fill (wait for the no it's not brigade) but always an independent garage willing to take your euros.Denmark and Norway not a great network for filling and no LPG in Finland .
No it's not. ;)
Actually, I thought it was just illegal at motorway services, I've been knocked back there before.
No it's not. ;)
It's illegal everywhere. Only motorway services give a ****.
Gaslow system was already fitted when we brought the MH. But, having lugged bottles about when we had a caravan, refillable is a no brainer
