whitebeach
- Dec 3, 2024
- 5
- 3
- B544
My Gaslow bottles (11 kg) need replacing @ £400 pounds or I could change to calor gas bottles for £120 (2x 6kgs). Besides having less gas should I stick with gaslow and why?!
Think your price for 2x6kg Calor a bit optimistic for new bottles and not refills..My Gaslow bottles (11 kg) need replacing @ £400 pounds or I could change to calor gas bottles for £120 (2x 6kgs). Besides having less gas should I stick with gaslow and why?!
We use about 150 Lt a year so that is 75kg costs us about £160. If it were Calor bottles it would be £487 in 6kg bottles or £300 in 13 kg bottles.I have been toying with this myself. Essentially a re-fillable system costs about £50 per year over the 10 year life plus the cost of gas. It’s therefore probably worth it if you use more than 3 or 4 bottles per year I think.
Is the £50 based on a twin bottle refillable system?I have been toying with this myself. Essentially a re-fillable system costs about £50 per year over the 10 year life plus the cost of gas. It’s therefore probably worth it if you use more than 3 or 4 bottles per year I think.
How do you work that out, doesn't matter what you've got value will be the same and most people will move their refillable system from one van to the next, one of our bottles now in 3rd van.(It will depreciate the value of your motorhome as well)
Can't say I've ever moved bottles from one van to another. But everytime I've bought one It's came with refillables or I've haggled off the cost of fitting refillables to it ...so I guess it does entice or put off some buyers.How do you work that out, doesn't matter what you've got value will be the same and most people will move their refillable system from one van to the next, one of our bottles now in 3rd van.
10 Years old I expect.
I'd sell my motorhome 'as is' in full working condition.How do you work that out, doesn't matter what you've got value will be the same and most people will move their refillable system from one van to the next, one of our bottles now in 3rd van.
Well as I said I've moved one bottle twice and the other once so are you calling me and Lenny HB shady?I'd sell my motorhome 'as is' in full working condition.
I'd be really annoyed if the seller removed a major bit of equipment that effectively stopped my new purchase being used.
It would be enough for me to decline to buy, unless they knocked off more than the cost of the (new) replacement item.
Also once you have a refillable system installed, the filler point, the regulator etc. why would you remove part of the system ?
Would you also remove the steering wheel, the awning, the loo, or the fridge or the cooker ?
To me that would be a con done by a shady dealer, hoping to sell you back the kit they have removed.
That's sort of been my hypothesis too. Is it a view that is widely shared or do some argue strongly for adhering to the 10 year limit?Also check the renewal date on the Gaslow bottles, if I remember correctly they used to be valid for 12 years which then became 10 years. As long as they are still in pristine condition, no rust etc, in reality I suspect a Gaslow bottle would last the life of the motorhome. But it means you should be fine for 15 years or so, as long as you are not going to sell it.
Had our gaslow system replaced last week as coming up to 10 years old it's not just the bottles that time out but the feed pipes as well, I feel I have bought peace of mind, was fitted by those lovely people at Autogas near Thirsk N/Yorkshire.
It isn't fit for purpose then & how have they tested all the equipment? I'd insiat on a working gas system as what am I going to use the first night?f you buy a new one you don't get a gas bottle,
