We recently had one gaslow refillable gas bottle fitted, keeping one red flogas next to it. The gaslow bottle is full.
We have found that when I turn on the gas from the gaslow bottle, the change over regulator doesn't switch from red to green. Whilst we do get gas to the oven, the fridge does not work as efficiently as when on flogas.
When I turn off the gaslow bottle and open the flogas, the regulator switches to green as per the image below and the fridge works properly:
Is the yellow gaslow valve the only on/off valve for this bottle? I can'e see any thing else anywhere. I turn this fully on, but could it be a pressure problem?
I understand that the the gas in the flogas bottle and the gas from the pump is the same thing, so should be as effective as each other. Is that right or are they different and one less effective as the other (similar to different grades of fuel)?
