Gaslow LPG indicators stuck on empty
T337
Newbie
I just filled my gaslow system up and the pump stopped so I assumed it was full. It took 20 litres and one bottle was empty, the other nearly full. So that seemed about right as I think I have two 20 L bottles. However the bottle that was empty is still showing as empty. Is it common for the bottle indicators to stick?
As a check, I've turned the central control towards that bottle, opened the bottle, closed the other one and lit a burner on the hob and that seems to be working fine.
Have you tried giving a gentle tap with something hard?
I've had dial type tyre pressure gauges stick on zero. A tap on the floor gets them going.
I've tapped them with my finger but not very hard.
