Gaslow Filler Pipe replacement
just looking
Hi all,
The filler pipe on my Gaslow which connects to the external filler point is starting to show its age and needs to be replaced. I've got a new braided hose from Gaslow, it looks like a fairly simple job to swap them over - is there anything I should be wary of?
Hi all,
I would check the dates on everything personally as looking at your Alugas / Gas It system I suspect it’s all due for replacement including your regulator.
Be extremely careful with the pigtail / regulator hose on the Alugas as while they look similar to others they are not compatible despite the threads being the same , you end up with metal to metal contact as the G12 KLF German hose doesn’t have the rubber as it’s in the male valve face .⚠️
