Ive managed to pick up a x1 Gaslow 6kg bottle + filler kit at a good price to fit on my Burstner T-Star.
The van looks like had the kit installed before at some point as it has 70mm hole on one side of the gas locker - now with an external vent fitted into the hole. I’m sure this is not an original thing as the vents are at the bottom in the floor (photo attached below)
So I’m thinking of fitting this myself and then getting it checked by a gas safety to make sure it’s all good.
From what I can see I’ve got everything I need apart from the hose that hues from the bottle to the original regulator.
As i currently have only one Gaslow cylinder (6kg) I wanting to keep one 6kg calor bottle in case a run out and need gas before being able to refill.
If prefer to have the 2x bottle connected via a dual changeover adopter/head. I definitely DONT like the automatic version as I’d want to know when/if im running out from the gaslow cylinder and using the calor.
So I’ve seen gaslow does a manual version?https://www.gaslowdirect.com/product/gaslow-w20-changeover-gauge-propane-standard-01-1630/
Can anyone explain how this works please as I don’t see any valve/cock that that will let me choose or set which cylinder inlet to use.
Also I see they do different version, butane & propane. With me again having 1x gaslow & 1x propane I’m I right in saying I’d need the below?
So what all I’d need will be:
1)
2)https://www.gaslowdirect.com/produc...-21-8lh-0-45-metre-regulator-hose-01-6010-ss/
Use my existing tailpipe from the calor bottle onto the gaslow changeover head.
Thanks in advance
Gaslow W20 Changeover Gauge Propane Standard
The Gaslow W20 Changeover Gauge Propane Standard 01-1630 has been designed to create a twin gas system for caravans and motorhomes. This manual changeover unit simply screws onto your bulkhead mounted 30mbar regulator and allows you to reconnect your existing regulator hose and with an...
1)
Thanks in advance
