Gas tank filling
St Austell
Vantage max
since 2014
Hope someone can help when to fill our gas tank in Spain as a quarter full when connected by garage none would go in tried mine and garage adapter.Has any one had this happen any ideas how to fix will try another station as now in Portugal
Thanks in advance
The Euro adaptor has two versions one with a non return valve and one without.
The ones with a non return valve often cause problems, if you have one with the valve you can knock them or drill them out.
Photo would help. Has it worked before or is it a new fitting? Something blocking the filling point?
Ask to borrow an adaptor from the garage to see if it's your adaptor or the pump.
I think hes tried that already. I'd say just keep trying garages we needed to borrow an adapter in Germany the third garage had a huge selection of ones to borrow with several duplicates I almost asked about buying one
