Gas smell in locker
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Hi all, is it normal to get a slight smell of gas in motorhome gas locker. All gas fittings where new when I bought motorhome last year and I have changed bottle a few times. Do you get a slight smell in the locker or is this an obvious leak?
Thank you
Anthony
They always smell a bit of it. They shouldn’t as they have drop vents, but they always do. Possibly more a smell from the pipes.
Reactions: JJ
Yeah, I smell it a bit when in bed as the locker vent is on that side, it seems to come up from under seat but I only smelt it at night, no smell during day. I always turn gas off at bottle & valve at night.
I replaced the braided pipes to the refillable system at the last habitation check. Put the old ones the the garage as emergency spares. Went into the garage a couple of days later and was puzzled as I knew I had no gas in there. It was very strong smell and even months later if you sniffed them you could detect it. It lingers!
The molecules can still pass through joints and the flexible pipes slightly too.
That’s why small enclosed natural gas enclosures are usually classed as potentially explosive atmospheres by the institute of gas engineers. And why there are drop out vents in the lockers.
You can detect the smell long before it’s an issue from a safety perspective. So a very mild odour is not unexpected.
In the other hand, a strong smell then isolate and check for leaks.
Thank you for replying, think I will get it checked as I only smell it at night when bed is made up so think it's coming up through the vent in locker
Yeah the vent in locker is near to the seats that make up double bed area so I only smell it at night and I always turn off at bottle and valve. Wife can't smell anything
Upvote 1
We also get it very slightly. It's worth buying some leak detection fluid as a check to make sure.
When our vans parked up I've taken to removing the regulator off the gas bottle and letting the open end vent, the smell then dissipates after a couple of days. We are lucky in that our van is 6' from the front door, so, easy to do.
Mike.
Mike.
Thank you for your reply 👍
:unsure:
How is that better than not disconnecting it which would keep the gas in as the pipes/hoses will still give off a smell of gas?
Mike.
Thank you for posting this. I'm terrified of gas and fire, so much so that I've never used the gas in our MH. Maybe if I had this to check for leaks I might be a bit happier to use it. Maybe not, who knows, but it's worth a try at £4.58 :)
If worried buy an electronic gas sniffer. Far easier for regular checks of the gas system.
I would but I'm terrified of alarms! I know, plenty will think it's ridiculous but it's all part of my anxiety and PTSD and so hard wired into me that, at my age, I can do little about.
I’m not sure you should be able to smell it when in bed, definitely in the locker, but it shouldn’t be entering the habitation area.
Think I’d be having a look to check connections, age of pipes, as even new ones can be sold out of date and look for the vents at the bottom of the locker, as it must be kept free to air. 👍🏻
No smell in the MoHo and can’t say I can smell gas in the locker but there is a rather nice vent at the bottom where the gas could exit. So maybe that’s why I cannot smell any.
It’s actually very unlikely that any retailers would sell out of date hoses as the recommended maximum shelf life is around 7 years for most hoses and can still be sold as new .
3 years for gas regulators.
But as you can see from this report it starts to get pretty complicated 😂🤬
Just be aware if you use washing up liquid to check for leaks be sure to wash all traces away as it can be corrosive
So much bad advice on here , if you can smell gas in your motorhome it’s an immediately dangerous situation, yes a faint smell of LPG in the gas locker is fairly normal but still worth checking.
Only a thorough properly carried out gas tightness test can confirm if you have a leak or not .
Gas detectors and LDF (leak detection fluid) are purely useful tools in the search for a known leak, they certainly shouldn’t ever be used as the primary method of gas tightness testing ⚠️
