SKI Mobile
I’m trying to open the outside gas locker door on our 2017 Moho but the key won’t turn either way. I’m definitely using the right key and have tried pushing the door in at the same time but no luck. Any suggestions?
Sadly not at the min as our Moho is in indoor storage several miles away. We got so cold we had to come home! The key hole is set in a white plastic square which if it’s like the other lockers pops out when it opens. Key just won’t turn in any direction - so frustrating!Any chance of a photo?
Think I tried all that with no success. Have come home to warm up with a view to trying again later!If you are absolutely sure it's the correct key ... try jigging it up & down and very slightly in & out whilst trying to turn it.
Powdered graphite or silicone spray would be betterWorth a try, thanks!
Thanks! We’ve ordered some lock lubricant and will see if that helps.Powdered graphite or silicone spray would be better
Thanks for your suggestion. There’s nothing in there other than the gas bottles as far as we know. We have spoken to Rimor who say it’s a common problem and suggest leaning on it forcefully. We will go back to our storage place armed with all the suggestions - lubrication, heat and muscles!Has something dropped down and fallen under the lever.?.. This happened twice on mine ..a watering can got wedged under...the cure was to shake the motorhome or thump the door and turn key at same time ...i have now made an aluminium guard so that the lever is not restricted.my lock is like this..
If it's a common problem, they need to find a solution. Take it to the dealer, it's their problem, not yours.Thanks for your suggestion. There’s nothing in there other than the gas bottles as far as we know. We have spoken to Rimor who say it’s a common problem and suggest leaning on it forcefully. We will go back to our storage place armed with all the suggestions - lubrication, heat and muscles!
This is a more common problem ! the solution provided worked for me tooHas something dropped down and fallen under the lever.?.. This happened twice on mine ..a watering can got wedged under...the cure was to shake the motorhome or thump the door and turn key at same time ...i have now made an aluminium guard so that the lever is not restricted.my lock is like this..
