Gas hose with M20 male fitting and M20 female connector needed
Worcestershire
Bailey Adamo 75-4t
March 2018
I am fitting a filter into the gas line so I can use a Spanish bottle whilst we are there for a couple of months.
Attached is a pic of the filter but I don’t know if I can fit this directly to the regulator due to space so might have to mount it remote somewhere else in the gas locker and pipe the gas from the filter to the regulator with a hose.
In that case I need a hose that has an M20 male fitting (from the filter on the left in pic) and a M20 female connector that goes onto the regulator.
Anyone know a supplier of these? I have searched the interwebnet but no joy yet.
Thanks in advance
No, sorry. That has two female connectors. I need one with a male and a female. Imagine a hose in the pic rather than the actual filter.
I’m hoping the filter will fit onto the regulator but it may be a bit tight for space on that wall of the gas locker.
Thanks in advance
Maybe try European camping shops?
https://www.fritz-berger.de
or Obelink in The Netherlands? I think they may not do mail order to UK but if you are in Spain they deliver there.
Oblelink is basically the IKEA of camping stuff and has as huge shop in Winterswijk. It has all those things you never thought you needed as well.
As already mentioned you will need w20 M and F hose which is something I have never seen .
We normally use either an elbow or move the regulator if required.
Sorry I can’t be more helpful.
Charlie
Something like this maybe?
Thank you. That is a propane gas bottle outlet pigtail. The larger male connection is way too big.
I think I am going to have to make sure I can put the filter directly onto the regulator and hence not need a hose at all. Fingers crossed
Go to Basildog he will sort you out.
Love a challenge.
How about this one.
Put this at one end of a standard Female to Female Pigtail, (as supplied by G7UXG above) and
you're fitted out.
That may just work. RH threads 👌 M20 👌 Might just have to get one to see if they can work with a gas seal inside the female.
Thanks. You would have made a good detective 😂
I was NEVER a Clown In Disguise, (but thank you for your compliment) ;)
I’ve just had this delivered for use at my static, it’s from a company I found online called “the caravan warehouse “ they may be able to help you out.
Will a W20 ‘caravan’ gas elbow on the regulator allow the filter to be positioned in a better orientation?
Do you really need the filter if gas outlet is lower than the regulator?
Might help as I could fit the filter in a corner. Thanks
That’s the issue. With the Spanish bottle the outlet is about the same level as the regulator. I am trying to be belt and braces . Thanks.
