Gas flow problem
Durham
LP Coachbuilt
Since 2011
Hi guys
Yesterday, gas cut out whilst using oven, cylinder not empty but no gas coming through. Changed to second cylinder and fine at first then cut out today, again whilst using oven. Swift secumotion system, left a while, pressed buttons and seems to have come through ok but for how long. Is this a oven problem or maybe regulator?
Easiest way to do a simple regulator check is as said already , fire up the heater.
Light a hob burner or all of them if you like and as the heater fires up if the cooker burners seriously die you can be pretty sure your regulator is suffering from lack of newness (knackered) .
Regulator. This seems to be reported fairly often.
Thanks guys, followed your advice. Put the cooker rings on, put heating on on gas and after about a minute the gas rings all cut out. New regulator required then, any recommendations or are all makes similar, thanks again, Paul
camel Try Autogas2000 at Thirsk. Their Cavagna ones will be a third of the price of a Truma, but may not have the secumotion feature ?
All you'll need to tell them is the pipe size (usually 8 or 10mm), and the orientation of the regulator (some have inlet and outlet in a straight line, others may be off set 90°)
Plus, it's a nice little run out from Durham to Thirsk if you want to call in for one !
We certainly keep plenty of regulators in stock just had a pallet of GOK regulators in on Friday too 👍
