May I ask how you are determining they are 1/3 full? I see no gauges in the photos.Does anyone have any idea why the propane gas stops flowing into my van when the bottle gets down to about 1/3 full? I've replaced pig tails and Truma regulator!! It gets expensive wasting 1/3 bottle every time!!!
Can you feel the 1/3 liquid gas sloshing around in the cylinder when you weigh it?Hi Chris, i weigh the bottle and compare with the tare or empty weight.
You do seem to have a strange problem.Hi Pauism, yes you can hear the liquid gas swishing around.
A shorter pipe without such a pronounced low point and a filter to intercept the condensates might help but shorter bottles are probably needed.They are not GasIT refillables as there is no inlet port. Looks like standard Calor or Flogas. We had a similar problem with flow in our last van before we fitted GasIT. The regulator needs to be well above the exit point from the cylinder or it will oil up. We had to change the regulator twice in 4-5 years. We then used the smaller bottles and the problem disappeared. Difficult to see how you can lift your though. :-(
