So i had a bbq point added when at Basildogs place to get Gaslow installed. It’s tee’d before the regulator, so its HP right? So I need a regulator for my Cadac 2 cook from the bbq point on the van! Forgot to ask![Neutral face :neutral_face: 😐](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f610.png)
I think it'll be low pressure, teed after the regulator ?So i had a bbq point added when at Basildogs place to get Gaslow installed. It’s tee’d before the regulator, so its HP right? So I need a regulator for my Cadac 2 cook from the bbq point on the van! Forgot to ask![]()
Tee’d BEFORE the regulatorI think it'll be low pressure, teed after the regulator ?
That's how mine is anyway with Gaslow and external BBQ point.
I just have the flexible rubber gas pipe with quick fit connections from BBQ to ext connection, no additional regulator, yours may well be different of course.
I'm suprised you weren't advised when it was fitted ?
Sobering read!!!!!Please read this…..
IMPORTANT: FIRE RISK WARNING
Please read this - it could save your life quite literally! It has taken some time to write this piece as it has been a very upsetting experience so please do take the time to read it - it has been painful for me but I felt it was necessary to put a posting on the forum to try to ensure others do...forums.outandaboutlive.co.uk
It’s a professional install with plastic covered solid copper pipe to the bbq point!If that’s T eed off before the regulator then it’s dangerous.
Not only would you need a regulator but also a HP hose to the regulator.
I stand to be corrected but the only difference I know in Cadacs is canister fuelled or direct connection to a BBQ point.It’s a professional install with plastic covered solid copper pipe to the bbq point!
I noticed you get hp or lp Cadac bbqs so do you get hp Cadac 2 cook pro as well?
A BBQ point is no different from any other has fitting, reading this I conclude that in this instance the fitting was not installed correctly in the first place, for the tee to move any amount the pipe has to be unsupported. Sadly there are many people doing work they should not be doing, my advice is make sure you check reviews and are sure anyone working on the gas is competent.Please read this…..
