Gas bbq inside Awning??
VW T5
Hi when you google if you can have a gas bbq in a awning/tent the answer is NO.
Why is that the case when we happily use our gas burners in the van?
Paul
West Sussex
Malibu Van 640 LE K
Since 2003
Carbon monoxide is the usual reason for not using a bbq in an awning but I am not sure about gas ones.
meanders
Funster - Life Member
Ipswich, Suffolk
Eura Mobil Terrestra
Since 2004
I don't know, but suspect a typical gas BBQ will be burning much more gas than a 2 ring hob, or even a little oven. The other risk inside an awning is fire. Areas around hobs are designed to be fire retardant. Awnings are likely to go up quickly unless very wet.
Greenwich, London, UK
Hymer MLT 570
The main reason for not cooking inside a tent is fire.
If you have ever seen just how fast a tent burns, you would ensure that no one ever cooked inside a tent anywhere near you.
As an FYI a tent the size of a motorhome/caravan awning tent would disappear in under a minute.
A hike tent can go in 20 seconds.
It's spectacular, and very dangerous as there is no time to get out.
The known issue of charcoal BBQ's is never use them inside any confined space.
There are several tragic stories of people doing just that
including one where the parents had the BBQ under the porch cover of their frame tent, so technically 'outside'.
A child asleep inside the tent never work up.
I see no problem with using a Gas Cadac or similar under a wind out awning without sides.
West Sussex
Malibu Van 640 LE K
Since 2003
This looks like the case Brains referred to.
Another sad case attributed to a cooking stove.
Hymer MLT 570
Unfortunately a brief google through just UK newspaper stories would bring up a dozen more very similar stories over the last decade.
When the recent story of the Grandfather/Grandson was initially reported, I said to my wife that I'll bet it's Carbon Monoxide poisoning.
Bottom line, as every Scout knows:
NEVER COOK IN A TENT.
MisterB
Essex
Adria 670 SLT
George Foreman grill assisted by a large lithium and inverter works well inside an awning in my opinion ...
