Gas availability at Newark show
golly
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
May be a bit of a daft question, but we are going to the rally at Newark in March and at the moment I have a full and a part used 6kg cylinder. As the weather is unlikely to be tropical :RollEyes: I'm a bit concerned we may run out, is there usually anywhere to get an exchange cylinder. The gas locker will actually take 3 x 6kg cylinders but I am reluctant to fork out for Calors extortionate rental agreement, have looked all over for an empty calor cylider but can only find Flogas:cry:
Gas
There was a gas facility on site last year and it was busy to say the least.:Smile:
Another gassing thread..........:Rofl1:
Sorry, back in the naughty corner:Blush:
Edit: I meant to point out that just because some dim witted French Copper had told you that you might be gassed at Newark, it doesn't make it true.
This has taken a sinister turn - there IS gas at Newark........
your gas should be enough even for Newark
I thought it probably would, but I haven't spent much time off hook up at this time of year so wanted to be sure.
Problem solved, thanks to forum member stacetop I now have extra calor cylinder. This really is an excellent forum.
