Garmin 770 Sat Nav hardwire kit
Arkley, Barnet, UK
Corinium Duo
Relative newbie
Has anyone managed to plumb in a hardwire kit for their Garmin 770?
I got a kit that seemed to match the power specs of the original Garmin cigar lighter unit (which works just fine).
I've got the cable route sorted and aware that there is an aerial for traffic in the Garmin cable. However, when I switch the ignition on, the 770 boots up, asks about file transfer mode and then says the current cable can't charge.
I'm not sure Garmin do a hard wire kit?
Hmm... Further research suggests the 770 in the "cable will not charge..." mode will remain fully operational just won't charge - obvs really, reading too much into the message...
I think then I can use the kit I have so long as the 770 has some charge to start with :giggle:
I guess I'll not get traffic unless I use my phone bluetooth connected...?
You'll definitely need to be able to charge the unit.
The internal battery doesn't last very long.
To overcome the "cable will not charge" problem what I did was to use the Garmin cable that terminates in a plug for use in the cigar socket and to hardwire a 12v cigar socket hidden under the dash. Used a piggy back fuse and earthing point as suggested by Gellyneck's photo. The 12v socket was about £2.00 and once connected to the official Garmin lead, I taped the lead in securely so that it won't shake out of the socket.
I had a genuine Garmin hardwire kit for an older Garmin sat nav for the car, that didn't work with my 780, basically got the same error message as you do. I did the same as Ingwe. Easy and works like a charm.
I've done that before in my Skoda and considered it but the existing cigar lighter cable is too short. Can you get a longer original cable?
The power cable for Garmin sat navs are "dedicated" to a specific model hence the reason it doesn't work with other units.
Quick update.
Above and to the right of the fuse box on the Boxer, there is a decent sized empty space (behind the trim of course) and I've discovered that the OEM power lead will reach from the front centre of the dash with the plug just hanging in the space. So, despite suggesting it's too short it does in fact reach.
An enclosed socket is on it's way which I'll wire in and I think jobs a goodun.
Will attempt a fee photos and a write up...
My be another option for those with a Garmin 780.
The device comes with a "cigarette socket" lead for powering, and also live traffic updates if you've got the MT-D version, however there's also a short usb A to mini usb cable supplied to connect to a pc \ Mac to enable updating software via Garmin Express.
This cable, as said, is quite short and difficult for me to connect to the back of a desktop I use so thought I'd try and see if a longer 3rd party cable would work. Given it was less than £2 and a reputable brand thought it was worth a shot and ordered one of these -
Amazon product ASIN B07FWF2KBF
and it works.
So, given they supply other lengths up to 5m (<£5) thought I'd try a 3m (£3) one -
Amazon product ASIN B07FWD7G8L
and it works too.
It looks like you can use it to both connect to a pc \ Mac for Garmin Express or power it whilst it's in use, albeit I've not tried to navigate with it as yet but the device will boot up into the main home screen. Obviously, you can't do both at the same time and you would lose the live traffic updates if you have a MT-D version.
Might be worth a try for those with a Camper 780 looking for an alternative power-up option.
Believe the Camper 770 has a mini usb connection (as does the Camper 760) so could be worthwhile trying a usb cable with the correct connectors.
I am considering buying a Garmin 780 but the charging difficulties outline above are putting me off. Doing a diy wiring job is way beyond me. Does anyone know if the Garmin dzl 780 LMT-D truck sat nave has the same charging set up, or is it easier to charge while in use?
Apologies if this is a dumb question
To my knowledge all Garmin units can be charged using a standard 12v accessory socket.
Thanks for that.
Argos are selling camper 780 at a clearance price at the moment in some locations. I'm also trying to figure if there is any advantage in paying the premium to get the DZL Truck version instead for a large Class?...or if either will do the same job?
Any advice appreciated! as I am techno illiterate !
I personally would go for the camper version, when plotting routes using the truck option in Mapsource (Garmin's mapping programl, the routes are generally all major roads which doesn't suit me.
Thanks for that response. I wouldn't want to do my driving on the motorways for the most part either. Food for thought
Thanks for that.
Go for the Camper 780 at the £200 price. Garmin have it on their own website at £299 (just down from £349). It has, virtually, all the same functionality as the dezl 780.
The discussions around charging solutions are only really around those who are looking to "hardwire" \ "hide away" the charging cable.
With our current Camper 760 we just route the cable from next to the drivers door A pillar, across the dash board in front of the Remis blind bottom rail, under this at the centre and down the front of the dashboard to the cigarette lighter socket next to the radio.
Thank you very much. That is very helpful and clear for me. I'll go with that, bearing in mind after reading loads of posts, that there are no "perfect" options!! (I must relax my ocd tendency to find the 'right' answer)
Just noticed this.
Might or might not be of interest to you?:unsure:
Only £75 less than a new 780 though from Argos.
Just noticed this.
Thanks for the heads-up
