Good Afternoon All! I'm looking for ideas to attach/screw fixings for storage in rear garage of Motorhome, any suggestions/photos will be gratefully received. Thanks
Here is my garage. As an example, I’ve used very different fixings for the winch into the floor, than the for the TV mounted to the roof..
Thanks, I like the idea of theseI fitted some of these rails in my MH. https://www.grasshopperleisure.co.u...7RoJvsumqVqoX969Zsw-aiEi6uxN-vCBoC5SQQAvD_BwE
Hi Carpmart. Looks good. I'm trying to post a picture of my garage but I'm afraid I'm a bit of a dinosaur when it comes to Tech. My kids will be home later, I will get help from one of them.Here is my garage. As an example, I’ve used very different fixings for the winch into the floor, than the for the TV mounted to the roof..
Hi Orion, I like the look of these, I've ordered some. ThanksFitted ours out on the back wall and elsewhere with extruded aluminium captive track - otherwise known as Unwin L or Cargo Track. It’s very versatile as the spring loaded fittings (various types available on eBay etc.) can be placed anywhere along the length, so we use elasticated straps between them to secure chairs, tables, recovery boards, etc. out of the way.
Extruded Aluminium Captive Track
Aluminium Captive Floor Track for commercial vehicles and mini buses. Heavy Duty Design SuitableFor Horizontal Wall Mounting or Floor Fixing Various Uses and Applications Single stud and double stud fittings both fit this track Dimensions: Size: L3000mm x W42mm x D9.5mm Gauge: 3.3mm Holes: ø20mm...www.nationwide-trailer-parts.co.uk
Single Stud Fitting (suits captive floor track)
Single Stud Fitting (suits captive floor tracks with 20mm holes). Ring diameter - 5mm x 39mm (outside diameter) Overall height - 61mm 1800kg Breaking Strengthwww.nationwide-trailer-parts.co.uk
Good tip! ThanksGot several of those Unwin rails in my van, they allow terrific flexibility .
One tip, as the fixings are easily removable, once set up, mark the places on the rail with a marker pen where you mount your fittings.
Makes life a bit smoother next time around
Pictures attached. After reading some posts, I was thinking of fixing Marine Ply, covered in Grey felt, to the rear wall and attaching Aluminium runners with fixings.Any chance of a picture of what you’re trying to fix things too, so we can offer correct advice.![]()
I saw this late last night and didn't want to appear stupid after drinking beer.( Only had three honest). But why have you got a TV facing straight down in your garage?Here is my garage. As an example, I’ve used very different fixings for the winch into the floor, than the for the TV mounted to the roof..
Worked it out - mine's the post with the photos on it, lower down:I’ve just posted pics of mine on another thread, with links to the fittings. I’m not smart enough to know how to link to it, sorry, but if you click on my name you’ll find it.
Thanks. I have ordered the Aluminium tracks![]()
Load Restraint Rail, Load Locks, I Track Fittings UK
Load restraint rails and load locks help to keep your cargo secure and can be used in trailers, trucks and HGVs. I track fittings work with straps to tie down loads during transit.www.nationwide-trailer-parts.co.uk
