Garage door frame (1 Viewer)
Vic
Aug 1, 2010
500
591
Please can I ask for some advice. I have a leak in my garage and I think the water is coming in via the small nearside door frame rather than the seals.
Have you any tips for removing the frame please?
The van is a 2017 Hymer, yes you read that right, Hymer coach built.
Thanks in advance.
Vic
funflair
20,180
33,835
Guisborough
MORELO palace
since 2012
I’m guessing here but think there will be a rubber trim inside, when you remove this you will find some screws and cleats that hold the frame in place, remove all the screws and holding cleats and the door frame should come away assuming it on not setting mastic (should be).
V
Vic
Aug 1, 2010
500
591
Not worried it coming out, as long as it keeps the water out. If not 522, what sealant should I use?
