Fusion 330 - Access to Oven Thermocouple
Low Profile
Since 2018
I'm needing to replace the thermocouple of my Thetford Duplex Oven.
Is access available to the rear of the oven and to the thermocouple connection by removing the blank vent panel on the right-hand side of the habitation door. Or do I have to remove the oven to gain access?
Any help appreciated.
Thanks Davie
Thanks for the info rb62 (y). It is very much appreciated. Davie
Thanks Davie
How did you get on with this. My Theftord duo grill is not igniting (oven fine) but works fine when manually lit.
First option will be to get in and clean the igniter but not sure whether I will take this further as manually lighting the grill from a taper lit from the oven is not that great a hindrance. Easy squeezy or a pain?
