Fuses??
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
I’ve recently discovered that my 2002 Hymer 584 is not charging the leasure battery while driving, it charges fine on EHU, just wondered if any of the Hymer experts on here know if is a fuse somewhere that’s gone please???(y)
Splash the cash and buy a meter Oh Please!. I'm sure Marie will handle beans on toast for 1 night :giggler::giggler:
If I recall correctly, the fuse is next to the starter battery.. near the pos terminal
any updates.. ?
did you find the fuse
Sorry Jim I never got around to it:xlaugh: on eu at home and the solar has been charging it for the few nights I’ve been wilding, but, I’m just about to go and do it now, so I’ll update you in a bit:xThumb:
To save taking the floor panel up to check the fuse, check to see if you have volts on the EBL input with the engine running. As Jim says fuse is by the starter battery it is a 50 amp Mega blade fuse.
Edit:
I think your battery is under the bonnet not under the floor.
Edit:
Yes, my starter battery is under bonnet:xThumb: and so is the fuse, or what’s left of it:xwink:
would starting the engine while still plugged into eh do this?
