Fuses from the 4th dimension!
Worcestershire, UK
Burstner A645 Active
Our ducato cab is Lhd there are two cigarette lighter sockets. The left one runs via a fuse in the dash behind a cover next to the steering wheel the fuse is good and works. The other (which I managed to blow the other day) operates via a fuse somewhere in the next dimension.
I have checked the fuse panels on both sides of the dash. Only the lhs one has one marked with the cigarette lighter symbol, this having been tested is fine and only works for the lhs socket.. All the fuses are fine in the other fuse board under the panel on the right side of the dash. There is a fuse box under the bonnet but none of these seem to show a cigarette lighter socket, and they are all fine. See pic.
Does anyone actually know where fiat in their wisdom located the fuse for the other socket?
Chances are it's aftermarket and won't be marked in any fusebox.
It will be piggy-backed onto any other fuse of the correct rating.
Start by checking, with a meter, any fuse of the same rating in any location....under bonnet, under dash and in hab area.
Don't just look, use a meter set to ohms or continuity
Could it be off the habitation battery? Checked those fuses?
They are both original ciggy lighter/accessory sockets. One is run off a low fuse 5amp if I remember and the other 20amp that I run my compressor off and is not marked anywhere but is in the offside fuse board.
Thanks guys, I found one fuse in the lhs fuseboard that what 15amps and was working, I'll see if there is another lower amperage fuse elsewhere. They are at least fairly easily accessed.
