fuse types on a 2023 Fiat Ducato
On Order.Carado V337
anyone able to help ID ing what type of fuses are used for the reversing circuit ( installation of a reversing camera )on a new Ducato
You found a reversing circuit? Couldn’t find one when I was looking for a reverse signal for my camera. Can’t help with fuse , sorry.
its for a reversing camera ..gather I should be able to take a feed from the fuse box and assuming that it would be on the reversing side ..
( don't have the van so just trying to have fused junction available as i'm ordering a load of other bits at the mo )
If you mean the fuses below the steering wheel they are mini blade fuses
Would you not just use a power feed from the reversing light and use whatever inline fuse type you wanted?:unsure:
mini blade fuses. fuse 35 as I recall is the reversing circuit
Don't know if this helps or not.
