Well it has a peel off sticker, but if I apply that internally to the windscreen the bar code is facing inwards, which I think, may affect it operating properly? I can’t fit it externally either, for obvious reasons…..’tis a quandary for sure….As #3 - we place ours top of windscreen in the middle.
There should be a “peel off” to the back which has a sticker which attaches to the windscreen.
I take the 3.2mtrs is width…. What did that cause you problems? Too wide for the barriers? Am I being thick?Stuck ours in the middle at the bottom of the screen, worked on most but we did have problems as we are 3.2 mtrs
No heightI take the 3.2mtrs is width…. What did that cause you problems? Too wide for the barriers? Am I being thick?
Many thanks…..problem solved.Don’t worry about which way the bar code faces, it will have no effect on the operation of the tag. More important is to site it if possible in the hatched area (frits) around the perimeter of the screen if you have an athermic one.
Emis advise fixing the tag in the "shaded area" around the rear view mirror. Since you don't have one (but maybe still have a shaded area along the top of the windscreen) just stick it in the area where there would have been a mirror if one was fitted.View attachment 727163View attachment 727164Where does this little blighter go? Having an A Class, I have a huge front windscreen, but no rear view mirror. Where, or how, does one affix this fulli tag for perfect operation?
Off to France, Spain and Portugal end of April……so help in this mere trifle would be very much appreciated….
I tried the “drop in the tray and leave it” method, and it has worked perfectly…..which means a clear windscreen!!!!I did have mine in black area at top of screen but often didn’t work. Now I’ve removed the bracket and just dropped it in one of the trays on dash top. Been fine there for 5 years including the express lanes.
Barcode is there incase it doesn’t auto/wirelessly connect.
