antprice1970
Hi all, just got to NEC for motorhome show and I have diesel coming out of fuel filter housing, any one got idea what I will be?
Thanks in advance
Thanks in advance
Thanks in advance
Got breakdown here now, it isn't leaking whilst he's running engine, he thinks I might have pushed pipe back in when I checked it???It’s very well known problem. You can try new filter and use the correct tool to tighten the housing, but most of use just fit a Complete new filter housing (already has new filter inside) and know that way it won’t leak again.
This often happens a while after it’s been serviced.View attachment 865688
Recovery are here he running engine and it's not leaking now he said maybe a pipe loose and I have pushed it back in. It happened on M6 near Birmingham and road was so bumpy????It’s very well known problem. You can try new filter and use the correct tool to tighten the housing, but most of use just fit a Complete new filter housing (already has new filter inside) and know that way it won’t leak again.
Hope so the young mechanic was clueless, will have to drive few miles and check it againFingers crossed for you. Nice simple fix if it was. Keep an eye on it
Hi, it was serviced in July been OK until I was on M6 near nec, the motorway is shocking, pot holes and I hit oneIf your van has had a service with a fuel filter change then it's likely that they did not use the correct tool to hold the filter casing to torque the top to the correct setting.
It’s easily changed even easier if you have the time/ability/wish to remove headlight, but you don’t have to.Managed to get motorhome home but it's leaking diesel from filter, I have messaged a seller on Ebay to purchase correct one. Watched utube video and dies not look too difficult to change (I think) lol.
Had this a couple of years ago, no leak whilst running stationary, recovery was about pack up and leave, let's run it around the carpark before you.Got breakdown here now, it isn't leaking whilst he's running engine, he thinks I might have pushed pipe back in when I checked it???
Hi, yes exactly same here, I managed to get drive it home so new housing been orderedHad this a couple of years ago, no leak whilst running stationary, recovery was about pack up and leave, let's run it around the carpark before you.
Soon as engine under load fuel everywhere. Was a Sunday, so recovered home. New filter housing fitted
Thanks for replyingIt’s easily changed even easier if you have the time/ability/wish to remove headlight, but you don’t have to.
Make sure the replacement is a OE or quality item, some of the eBay are cheap copies.
Hi, is the UFI replacement filter good quality as I don't want to buy cheap one but searches all dhow this one. Good replacement?Fits Fiat Ducato Fuel Filter Housing Complete Peugeot Boxer Citroen Relay 2.3 3.0
New Complete Filter Housing With Fuel Filter Fits Fiat Ducato, Peugeot Boxer And Citroen Relay 2006 Onwards. This Comes Completely Assembled And Torqued Up To Correct Settings Ready For Fitting And Should Not Be Disassembled. We Have Done Our Best To Show Compatibility For All Vehicles This Part...coastalmotorhomes.co.uk
Hi, thank you I have been in contact with them and just ordered one from them on ebay. Thank you for replyingYes. UFI is ok.
I linked to coastal motorhome above. They sell at £90. Don’t know how much on eBay. Coastal also sell via eBay. You can tell as their photos have their name across them.
You can buy cheaper but UFI filters are more expensive and cheaper ones not any good. Yeah Fiat charge £199 for replacement but after shopping around and getting recommendations from funsters, coastal motorhomes where very helpful and replied very quickly. 12 months warranty also£90 seems very expensive for a fuel filter but I saw further up the thread that Fiat charge £250!
That's the danger. You shop around and think you've got a bargain but the product might be substandard.You can buy cheaper but UFI filters are more expensive and cheaper ones not any good. Yeah Fiat charge £199 for replacement but after shopping around and getting recommendations from funsters, coastal motorhomes where very helpful and replied very quickly. 12 months warranty also
I was talking generally rather than about this particular product.Coast motorhomes have a good reputation on this group, and if it's crap I will personally take it back and shove it up his nose
Yeah, alot of rubbish online I agree, I always ask on the group for recommendations. The original fiat fuel filter and housing on this year where awful, so I have read and prone to leaking and the breakdown mechanic that attended yesterday didn't have a clue. TypicalI was talking generally rather than about this particular product.
Hi, I purchased a new filter housing from Coastal motorhomes and fitted it yesterday with the help of a utube video. It was fairly easy to be honest. Thanks again for your helpIt’s very well known problem. You can try new filter and use the correct tool to tighten the housing, but most of use just fit a Complete new filter housing (already has new filter inside) and know that way it won’t leak again.
