Hi, has anyone tried an Efoy fuel cell?
Fab, thx Martin - other than the cost (£2k?) is there a downside? Seems to just top up electricity endlessly, is it like being in electric hook-up all the time?We have one and it does what it says on the tin.
Martin
Soz, I’m not only new to MoHos, but also forumsRally Chat?
Is it easy to instal/attach? (Imagine a guy who finds wiring a plug a little tricky - not that we need to any more )
Hi SueThe fluid costs, but I'm not sure hiw much, and how long it lasts
@Sundowners had one i think.
Good alternative to lithium batteries??
0.9l will give you 1kwh
Martin
The fluid is about £5 a litre if you buy the 2x10 litre box but delivery is expensive for hazardous goods so you are best buying 2 boxes, 0.9l will give you 1kwh
I have just bought 40 litres of fuel so about £200 ish but it will last at least 3 years as it is not used that much, you mentioned "insurance policy" that is exactly what it is for us, what works for one person does not work for all but as long as we go into it with our eyes open it is OK.Ouch
I did have in the back of my mind fitting an Efoy.
I have 400Ah of LiFePO4 and use about 1.2kWh per day. So on top of the £5,500(ish) price tag for the one recommended for my setup, it COULD cost a further £160 per month if no solar
I'm sure in reality it wouldn't be anywhere near this high, but as I was only thinking about an Efoy as a kind of insurance policy (3 days with no solar + ill so can't drive = sods law), it seems a little OTT for me
With 750w of solar that will likely be able to angle for winter months (working on the design for this at the moment) and a true 60A per hour whilst driving (have to love LiFePO4 charging efficiency), I think a small silent (lol) generator will do as my insurance
(not knocking anyone else's choice - we all have different needs - just thinking aloud about our own setup)
Ouch
Horses for courses you see our Efoy is just to sit on Auto in the shed and keep everything tickedy boo not for mainstream power, for that you are right a genny fits the bill.IMHO .a small 'silent' Genny is far more versatile than efoy and takes up similar space------- it can produce 240v and 12 volt --- could run all day on one fill of fuel if necessary-------- we have used ours several times to get us out of trouble------- it is our insurance that is why we never travel without it-------- even with our caravan!!!!!!!!!
The latest Efoys have lithium settings too. Can you update the software to overcome your problem?I have an efoy, fitted it in my previous van refitted it in my present van, they are good and suppliment the solar panel's, if you can afford it I would recomend it, BUT having just installed lithium at the moment It won't let me start it as the lithium battery is showing too much power in it, Over easter I am going to see if that continues. It will be a good test as when they built mine both the TV's, Sat Box and 7 or 8 mains sockets work off the Victron inverter.
I am surprised that you can’t turn it on manually, but I can understand it not working in “auto” as it senses voltage to turn on and off and your lithium’s will sit at a steady voltage.I have an efoy, fitted it in my previous van refitted it in my present van, they are good and suppliment the solar panel's, if you can afford it I would recomend it, BUT having just installed lithium at the moment It won't let me start it as the lithium battery is showing too much power in it, Over easter I am going to see if that continues. It will be a good test as when they built mine both the TV's, Sat Box and 7 or 8 mains sockets work off the Victron inverter.
I thought they were as effective as mains? Solar only tops up battery, but won’t give you mains style power, or am I wrong in that?I have an efoy, fitted it in my previous van refitted it in my present van, they are good and suppliment the solar panel's, if you can afford it I would recomend it, BUT having just installed lithium at the moment It won't let me start it as the lithium battery is showing too much power in it, Over easter I am going to see if that continues. It will be a good test as when they built mine both the TV's, Sat Box and 7 or 8 mains sockets work off the Victron inverter.
Yes, you are wrong Both fuel cell and solar are for battery charging Mains can come from an inverter running from the batteries.I thought they were as effective as mains? Solar only tops up battery, but won’t give you mains style power, or am I wrong in that?
