oh,,ok i seems warm temp inside is 9 c is that still too cold ,,Warm the body of the valve up a bit, it's still cold out.
Mike.
thanks ,,i get a peg ready ,,Mine just resets when warm enough.
When I leave the van, I push it down to 'dump' the boiler water. When empty the boiler I reset, just so I know if there have been cold nights.
Sometimes it does refuse to stay up (closed), so if I'm about to travel I either;
Use a clothes peg to lock it in the closed position, fill the tank as usual and leave it like that until I'm parked up, but only if it is nowhere near freezing point.
If it is, I run the hot water boiler until the boiler tanks is well warm and the valve stays closed.
7 degrees is what they list as the required set temp.oh,,ok i seems warm temp inside is 9 c is that still too cold ,,
Yes, dumps water at 4 and is able to reset above 77 degrees is what they list as the required set temp.
