Frost damage
Devon
Swift Bessecar 584
Since April 2019
Our travels wouldn't be interesting if we didn't have problems on them.
This time water gushing out from fresh water tank where outlet pipe joined tank.
We've been in - 5 to - 8 degrees at least in Castleton. Wednesday pipes frozen, had heating inside, tank heaters on. Looked in fresh water tank film of ice on top. Sorted all this out without a problem.
Yesterday, similar problem but as we were driving to Yorkshire thought allow to defrost naturally whilst leaving tank heater on when driving. Manual said you could do that.
Arrived at M18 services went for coffee then returning back to van, water pouring out from underneath. Ahhhhhhhhhhhhhhh.
Seems fault point was where outlet pipe joins water tank. Decided to head home but as mid afternoon booked into Chatswirth CMC. Ha...... covered in frost.
We have frost tank heaters which should come on when temp is below 2 degrees.
Seems this may not have happened WHY do you think?
If they worked why what's the point if the lagged pipes freeze up?
What's the point of of them if the water can get out of pipes. Suppose fact the empty tank button was on no, might contribute to the problem.
All I can think is that the journey broke up the layer of ice which dropped down to the outlet pipe blocking/freezing it up.
Why did it pour out when we stopped after driving for over 1hr and not on journey?
Welcome some thoughts.
I expect the water poured out when the frozen block that caused the damage melted. Lagging only delays freezing. If the pipe is lagged I guess it is external not internal, the chill factor below a vehicle can be considerable whilst it is moving and wet lagging could reduce the temperature well below the ambient temperature.
On our static van we have heat trace wiring from below the ground up to the floor where the water enters the van, this works great but it’s 230v not sure if you can get 12v🤷🏻‍♂️
Yes you can Paul, I use it on our grey waste pipe from the tank to the drain tap, so we can still dump grey waste in freezing conditions.
Hiya,
First time I've ever seen this before but looks good. I had an issue the other day where the drain valve pipe froze, luckily it thawed and no problem. Just a quick question, where did you run your 12v supply from?
Useful, thank you.
I notice it says that it can run up to 60°, so would that start to melt a plastic pipe, or do you put lagging around it first?
Other question: do you just run one length along the pipe (if that is sufficient), or do you wrap it round like lagging - if so, how close are the loops?
Thanks >:)
Hiya,
Our fresh and grey waste tanks are under our van, so I fitted thermostatically controlled heat pads to the bottom of our tanks, and the trace heat cable is linked onto the grey waste heat pad, which are powered from our hab battery.
Useful, thank you.
Thanks >:)
The cable I linked too was just picked to highlight that the trace heat cable is available for 12v.
The cable that I'm using from memory can get to 36c, but it is unlikely to get anywhere near that due to the environment that it is operating in the cold weather.
The cable is quite stiff, so my cable is cable tied so touching the underside of the pipe from the tank working on the basis that heat rises, and in turn the pipe/cable is lagged with foam type pipe insulation.
The cable works by the pos and neg wires in the cable being separated by a semi conductive material which its electrical resistance reduces with heat, so it heat output is self-regulating.
As it heats up, the resistance reduces so less power is used and the cable would eventually reach an equilibrium of power supplied to heat produced.
As the semi conductive material between the wires is a conductor, the wire ends are not required to close the loop, as the semi conductive material is doing that.
Useful, thank you.
Thanks >:)
No, it would not melt the pipe. As your water heater heats water to 60 degrees, and the pipes are fine with it.
Brilliant,
Mine is the same on the Kon tiki, I have heaters in the tank but the pipe still freezes so I'll fit this and pick up the live and neg from under the van somewhere.
Now I am home it seems that there seems to have been NO DAMAGE.
I've been under MHOME and pipe end from fresh water tank was almost out. The "L" shape connector to the tank had turned.
I've reconnected everything, filled tank..... no leakage. 👍😁
I've emptied and refilled, left it standing and about to empty again now, but still no leakage 👍😁
Checked pump which is working OK.
I will tighten tank connection and probably buy some good replacement pipe lagging.
Onwards to the next journey. 😁
