SOLD Froli bed system
Hellski
Cheltenham
N+B Arto 76 LE
Not sure if of interest to any fellow funster's?
Purchased last year and now not required, the Froli bed system suitable for either double, single or twin bed arrangements and includes the netting used if fitting the system on slatted bed arrangement.
System includes:
2 x "Bed in the Box"
Each contains - 60 spring elements, 50 x regular & 10 x soft (light blue); 60 base elements; 10 tension clips.
Also included:
2 x Rolls -
This mesh tressel enables the Star Mobil bed system to be fitted onto slatted beds, thus providing more stability. (Please be advised, this has been pre-cut to suit my application but can be laid to suit other applications as required with no detrimental effect to the system.)
The system cost me £350, Priced to sell at £150 + P&P, although collection would be preferred due to bulkiness of netting
Manuafactures Details:
With a passion for great sleep Froli has developed a bed system that relieves your back and spine in a way that helps your body to experience deep relaxation. The Froli bed system allows air to flow around the bed and supports the mattress and pillow providing supreme sleeping comfort. The system is designed to be installed by both consumers and manufacturers and due to its unique flexible design, it can be fitted to any shape and size of bed base.
Easy to assemble, readily adjustable and extremely flexible with a variety of dimensions, Froli Star Bed system provides ultimate sleeping comfort. (The neck and spine in particular are supported in a comfortable, orthopaedically correct fashion.)
FROLI Star is a luxury sleeping system which saves considerable space and weight, fits any bed size of mostly rectangular shape, and can be an ideal solution for improving your bed comfort while you are travelling in your campervan. It is especially suited to those building expedition vehicles, or intending extended overland travel, as it provides a unique combination of tailored comfort with proper mattress ventilation. With its construction height of only 4.3 cm, FROLI Star manages to provide optimum suspension of up to 3.3 cm.
Froli Stars consist of base elements that clip together. The springs sit individually on top of these bases and provide independent suspension. They create an "articulated air-flow surface".
Your mattress now rests on a surface that allows air to pass through, made up of many individual springs that flex and adapt to your body shape, weight, and movements.
The kit covers approximately 17 sq.ft or a bed size of about 76"x32" (193cm x 81.28cm). If your bed is slightly bigger you may need Froli STAR Mobile Bed System Extension pack. Another optional accessory is Mesh Base for Froli Star Bed System (2m X 950MM X 2MM THICK), which enables the Froli Star Mobile Bed System to be fitted onto slatted beds, thus providing more stability.
Froli "Bed in the Box" contains 60 spring elements, 50 x regular & 10 x soft (light blue); 60 base elements; 10 tension clips.
Yes, of course Mark and no cutting required for your installation(y)
We'll need to organise a meet up, as it will be easier than posting the netting.
No worries - glad you got a quick sale (y)
