Thanks Mike I’ll check the chimney but can’t get at the burner because there’s not enough room between bottom of burner and floor. Not heard a rushing sound so maybe I should check gas supply although it burns hot.Sounds like the gas system is not generating as much heat as the electric, have you checked the burner and chimney for dead spiders etc? Is it making the usual rushing noise?
Hope this helps
Mike
Hope this helps
Mike
Thanks Smiffy will do as you suggest.Check the flue and give it a clean, also see if it has the spiral heat defuser down the top of the flue…![]()
That’s what I suspected Xsparks as the gas is getting through but not much sound. Looks like I’ll have to remove the fridge to get at it. Thanks to everyone for their support.Similar happened to mine it was a partly blocked jet. It would light but not cool correctly.
We use the van regularly and the gas fridge too I doubt it is the coolant otherwise it wouldn’t work well on electric.How long have you had the van and when was it last used on gas only ?
Probably flue or burner then.We use the van regularly and the gas fridge too I doubt it is the coolant otherwise it wouldn’t work well on electric.
